So as my N/A is starting to show signs of BHG, with spiking temps, all my lines are good, radiator flows just fine, did a full flush, replaced the thermostat and swapped the water pump off the turbo one which was rebuilt about 20k miles ago (i think) when the previous owner blew the headgasket and parked it, i picked it up about 8 months later. The water pump was in real good condition, seal looked good, turned with some resistance, but smoothly, resistance was the same in the pump off the N/A i replaced, so i assume it's normal. The pump i replaced didn't look too bad, had some signs of white corossion, and the seal looked a bit sketchy, but it should've worked.
Anyways onto the point, i'm starting to realize this car is about to be in the same condition as the one with it's engine on a stand, so i need to start rebuilding this 7mgte!
I talked to a machinist at a good NAPA machineshop, it wasn't the guy i was hoping to speak with though. I asked about a hardness test, and he looked at me weird, tried to tell me i was talking about something called a ... Bernielle test i think he said, which runs about $600... i was planning on dropping my head off today to get prepped, hopefully my preferred machinist is there, how do i approach this? Do i need to look for a new shop? (If anyone knows a good one in the Seattle area!)
Also i've previously asked about headgasket thickness, since i don't know how much has been taken off in the past, it's been rebuilt by a toyo dealer at least twice. They said they can look at specs, do measurements... is this possible?
