Okay, first problem... My car seems to be really hard to start when cold, but starts fine when warm. Today, (keep in mind it does this all the time, it was just worse today) it was raining, and quite a bit colder than usual, and I swear I didn't think it was going to start, I would crank it for five seconds at a time, and did this probably seven or eight times, before it finally started. When it finally starts, it will idle really low, then jump up to normal RPMs within 1-2 secs. Would a broken ECU temp. sensor cause these kinds of symptoms? I just cleaned my CSI...
Also, when idling, it will miss (I think thats what it's doing, feels to me like it will shake slightly every once in a while) and idle fluctuates slightly every once in a while. It will be at 600 sometimes, and at 900 others, it seems to be perfectly smooth when idling at 900, almost like the car isn't running!
Then, last night, i started to boost slightly, then backed off, and rpms went down, almost died, but then recovered. Also, it is bucking SLIGHTLY under light acceleration... whats the deal?? Thanks!
