Haltech E6K
D
davidb
Guest
Looking to upgrade to a stand alone, does anyone have any advice. Working on a budget, due to the fact that I had my 7m totally built with rods, pistons, head work, and a complete new turbo system looking at haltech e6k for the simple fact that my wiring harnes is shot so i think for my goal is to make 500 plus hp i need stand alone and i all ready have every thing i need for fuel system 720 inj weldon fuel pump sx reg for fuel need some help thank you and any ideas would very appreciated thank you new to the supra world looking to have iots of funnn : :
bluemax
The Family Man
Orange County, CA
If you're real serious about tuning, especially if your going for high boost pressures, I don't know of any reliable and cheap way to do it. You're going to want fuel and ignition tuning. I guess you could get a cheap fuel tuner and a MSD ignition. But for me, I wanted a reliable full stand alone management system. So you're looking at Haltech E6 or E8 or E11, AEM or Electromotive TEC3. The Haltechs and Electromotives are built for racing and require a custom installation. It can be done but requires a lot of work. There might be some custom installation kits for the mk III now, but a few years ago there wasn't.
The Electromotive TEC3's ignition is accurate within 1/2 degree or crank rotation. But it has that darn trigger wheel that has to be mounted on the crank and of course the Electromotive ignition coils you'll need to get custom wires. From what I've read and seen on other sites that offer the TEC3 and Haltechs, the TEC3 is the best.
The AEM is a stand alone that plugs right in to where your ECU is. It replaces the ECU. Its a little bigger than the Toyota ECU but will fit. It isn't as accurate as the TEC3, but will work with all the factory equipment. For street application, the AEM is the way to go in my opinion.
Of course these stand alones are $+1.5 K new and require a lap top to program. You might be able to pick up one used cheaper.
I'm in the same boat as you, I broke the piggy bank and got an AEM. Oh... the AEM support for the MkIII is real good. I wish I could tell you how it works, but I haven't installed it yet. I'm still working on the rebuild.
LoL
Let us know what you do.
Clifton
Scottsdale, Az
The 7m ignitor will not work with it. You'll need an ignitor from Haltech or get one from a Volvo S90 3.0l. I'm considering the same setup and found this on a Haltech board.
