Well recently my supra started smoking very bad! I can't figure out why and need some help! The first time I noticed this was right after I did a pull to about 120MPH and came to a stop, when I took off from idle it let out a decent cloud of smoke, I didn't think much of it but since then it continues to smoke.
Engine specs:
7mgte rebuilt 15k miles ago
Probe forged pistons 1mm oversize
Cometic HG stock compression
ARP headstuds
57 Trim turbo ~16psi
MaftPro
550cc/walbro255lph/aeromotive fpr
Intake/intercooler/exhaust etc
Here is what I have found. Pulled the plugs and cylinders 1-3 are BLACK. 4-6 are normal. 1-3 pistons looked damp, 4-6 dry and normal. When revving with the oil cap off, there is a distinct puff of smoke that comes out.
Here are the plugs in order 1 through 6
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11001.jpg
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11002.jpg
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11003.jpg
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11004.jpg
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11005.jpg
http://img.photobucket.com/albums/v313/cyfi/Car/CyrusSpark10_8_11006.jpg
Things I have checked:
Compression
PCV- Completely clear and unrestricted
Not losing coolant
I always overfill my oil, so I can't really tell if oil level is dropping, it still reads over full
Tried leaning out my MaftPro very far and it would still smoke from the exhaust
Fuel pressure looks completely normal -38 PSI idling with vacuum
Oil pressure is normal
Vacuum - Still strong - 18" hg at idle
Only seems to smoke when it comes back to idle after revving. The longer I let it idle the worse it will smoke when I hit the throttle. The smoke seems gray and honestly does not smell like burning oil, but I don't see what else it can be. The smoke from the crankcase concerns me.
Car still has plenty of power and runs great, if it wasn't for the smoke, I wouldn't know anything was even wrong.
Here's the video.... Sorry for the bad quality video/audio.
Warning - this is an emotional time for me. :biglaugh:
[video=youtube;VHNkGdm4n1I]http://www.youtube.com/watch?v=VHNkGdm4n1I[/video]
Thanks
Engine specs:
ARP headstuds
MaftPro
Compression
1 - 175 psi
2 - 170 psi
3 - 170 psi
4 - 175 psi
5 - 175 psi
6 - 175 psi
Turbo - No shaft play or any evidence of leaking, no oil in exhaust downpipe and very little oil in the intake2 - 170 psi
3 - 170 psi
4 - 175 psi
5 - 175 psi
6 - 175 psi
Not losing coolant
Thanks
