Hallman Pro MBC Q's
Nougie
28
CA
Picked up a Hallman mbc locally and installed it. Easy as i thought. I now have a few Q's reguarding the mbc. Currently its getting its boost source from the CT26 Housing Nipple/line and of course back into the wastegate actuator. I did multiple test runs only seeing 6psi with adjustments going over x2 full turns after testing. Still nothing. Everything is installed correctly.
Does the mbc need to sit a certain way for maximum results?
Can this mbc be shot?
Being that hallman makes reputable BC can it be leaking?
or am i just a retard?
Nougie
28
CA
well quite honestly after the 2 full turns i didnt see any change so i just decided to call it a day and stop disturbing my neighborhood with mutiple pulls of a loudass supra lol. By any chance do you believe that that may just be my problem? im sure two full turns should have been enough for at least ~2psi?
