HA! S-AFC pinout manual is wrong.
SimpleIcon
Brigadier General
I believe the pinout is upside down and the IGN wire is completely wrong... After I noticed this, I still got some wires wrong.
I used some of the pinouts I found on the board and I still got 3 wires wrong.
Anyone know what wire colors of the RPM, knock, and airflow signal wires are?
Any help is appreciated.
Thanks alot
Idealsupra
Orlando
www.tampabaysupras.com
here ya go:
the only difference with the afc and the afc2 is the knock sensor wire i believe...the coloring should all be the same still and obviously the ecu pinout is the same still.... hope that helps
