H&R w/illuminas question.
Atsushi7mgte
203
Oahu, Hawaii
So im scoring a mega deal on some H&R springs with tokico illuminas. Every site ive looked at only lists the illuminas for TEMS but my supra doesnt have TEMS. The guy said i can run the illuminas i just have to have them set all the way hard all the time. is this true?
JDMMA70
2,550
Houston
The ones you have are for tems. Just set it where you want it. Sport should be fine unless you want full firm all the time. Im running the same setup. Except I have tems and I leave it on sport all the time.
mkiiichip
1,434
WI
You can use the TEMS shocks. Just set the adjuster, on the top, the same on all four (hard or soft) to your taste, and your good to go.
You just wont have the electronic adjustment, on the go, it was designed for. More of a "set it and forget it" deal.
The TEMS car still makes adjustments, whether in normal or sport. The OP setup will not change at all.
