Buildt my own meter with the schematichs from Dr Js site.
First I ran a wire to the diag block connecting to the Vf1 terminal.
Power from the cig lighter and ground on the steering column.
Only 1 led turned on and that was all.
Tried moving my groundwire to E1 as its supposed to be the ECUs ground, then I got nothing at all.
If I meassure with a DVM between Vf1 and E1, I get the normal voltage about 2.5V, flipping up and down a little but thats ok.
I put a 7812 voltage regulator to get a steady 12V feed to the meter, but I dont think thats why I get the strange readings.
And yes the meter is calibrated and works perfect when I checked it with a variable Volt output and my DVM...
Ignore the red wire since it was for calibration only.
suprafredde
suprafredde
