gte valve seals on a ge ....
Idealsupra
Orlando
www.tampabaysupras.com
MKIIIChucky said:
I can get a set off valve seals for cheap but there for a 7mgte , i was wondering if i could use the on the N/A ???
they should be exactly the same.... the heads are.....
having said that since ive never TRIED or looked into TRYING to do that i would do a little more research...
even though its an act of god if im wrong :biglaugh:
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
there is no differance. some manufactures are just not aware of that. with the exception of a few gaskest and seals, the rest are the same between both motors
MKIIIChucky
101
south jerzy
sweet , couse i just bought a oem size hg thats metel , bout to get them valve seals n arp head studs . + i might be gettin a new oilpan for cheap soo i can have a bung welded in w/o takin mine off ! : )
MKIIIChucky
101
south jerzy
yea, i was told the only thing diff. between the ge & gte head is that the cams in a n/a are better then gte cams , couse ive herd of people installing them in the gte head & gettin 30+ hp on the dyno depending on the mods done
