GTE Cressida with leaking dissy wanting CPS setup
Supra469
495
Maryland
I have a 90 Cressida that had a leaking distributor that I believe resulted in rod-knock. I now have a new GTE built motor and this dissy is leaking also. I've relpaced numerous O-rings, my breather tubes are clean, there's no build-up in the valve covers etc. The oil leaks from the cap and not from the head.
I am tired of the burning oil engulfing the car, smoke leaking out the grill and sides of the hood and oil puddles where I park.
What do I need to convert from dissy to a CPS setup?? I have coil pack and CPS, what else? Thanks.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
you swapped to a GTE and it still has a distributor?
weird, either way don't forget the ignitor, and you'll need to get an aftermarket tachometer, or find someway to convert your current tach..
