GS300 Idle Problem
JASONA70
nomnomnom
Oct 27, 2006
743
socal
the car starts up fine and everything runs well. i turn on the car and i warm up and idle for about 3-4 minutes and then the rpm throws all the way up too 1k from 800. any clues? i cant find any disconnected sensors or vac.
here is a pictures:
btw if anyone has a exhaust manifold heat shield please PM me. It took me a week to remove all the surface rust and switch out all the blown seals, the previous owner was a ricer, he pulled out the OEM intake box and put on an ebay brand air filter which you can literately see through if you held it up through the light. he also cut the a/f sensor tube :cry: i had to work with what i got.
