Ground Wire kits
mkIIIman089
Ohio
Well... DUDE, I've seen a couple magazine articles with WRX's and 350Zs that prove they do increase performance by a few HP. They won't do jack unless you properly install them though.
EDIT: whatever that was you posted on ebay is junk though.
koulee
497
The three main grounds that you should do are:
Chassis to negative
Block to chassis
Tranny to chassis
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
So you're saying the kit is unnecessary, just make up some cables ensure good grounding, and corrosion prevention, maybe?
shaeff
Kurt is FTMFW x2!!!!
10
Around
you'd be better off just buying some heavy ground cable, and making your own. it'd probably be cheaper, too.
-shaeff
bluepearl
326
pa.
The only way a ground wire kit,or for that matter new ground wires will improve electrical performance is if the current wires or attaching points are bad. Check you're grounds with a DVOM. If they are clean (no resistance) save you're money.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
hey when i had my clutch changed they grounded the tranny to the frame and it killed the power in my car i could only run 4 psi but when i removed it bam! 10psi. maybe its cuz its a 1g?
lagged
1991 1JZ
new rochelle
maybe cause something was wrong...
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Have you looked at the stock grounds? Due to the small guage they place a definite restriction on the amount of current passed. Even on a new car replacing ground lines with 4GA can make a big difference (big being a relative term here).
And yes, you can get the same result building your own ground lines. Just run them well. If the battery is well grounded to the chasis, you can use the chasis as a grouns point, but there is resistance there. The ideal and most responsive method is to ground it ALL to the battery. Of course at this point the difference is so small that most people would never notice it.
bluepearl
326
pa.
how much current is being passed on a lightly modded car? or stock for that matter? I want proof. Big being a relative term, what enhancements can i expect to see on a electrical system that the stock gauge wiring is used, if,in good condition? I will end this with we agree to disagree.
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Last summer when I had my n/a dsm, I made my own ground wire kit for the car and didnt really notice anything as far as performance goes, but it definitely smoothed out the idle, started easier, and just made the car as a whole feel more "smooth". I had 4g cable that I got at a car audio store (probably not the cheapest, but it was just a fun day project), the ends from fleet farm (dont know if they are anywhere else but WI) and just linked my different grounds together and they all went to the negative battery terminal. Its pretty self explanitory?? but I still have a diagram if anyone interested in seeing how the setup works.
bluepearl
326
pa.
I am glad that you seen an improvement with you're wiring upgrade. the original ground system was bad and you fixed it.
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
Whether it was "bad" or not I dont really know because my car wasnt running abnormally or anything. The stock wiring was a lot smaller though. I just thought it would be a fun, cheaper project so I had at it. The result was more than I actually expected so why not give it a try? I just got my supra so I'll definitely being putting one together for my spring tune-up. When I do that (if nobody else puts anything together beforehand), I'll take some pics, and post all the results, if any lol.
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
CPT Furious: I are a Crew Chief. Every else thanks for the input, there sure is gonna be a lota new shiny crap in the poop mobile
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
eviltwins said:
Chassis to negative
Block to chassis
Tranny to chassis
are these the only things i need to re ground for this to work?
I'm not sure about those (not saying they are wrong), but in my setup I had the block, transmission, frame, firewall, intake manifold, and the alternator. I didnt have a separate ground going from the - battery terminal to each of these points individually, but some were linked together. If you look at a
420a from a n/a 2g dsm you'll figure out where the wires went.
