Grey connector on ignitor
Tojo
11
Up North in NORWAY
The grey connector? what is it good for ?
tissimo
Stock is boring :(
Melbourne, FL
Its like a noise box or something.. The jza70 has it elsewhere were as the soarers havei t on the ignitor liek you have..
aphxero
787
Seattle, WA
It's not required but it helps filter out noise on the ignition. Check to make sure the black wire is continuous to coil power (siwtched from ig2) and the white is continuous to e2 (sensor earth) or chassis. It especially should help if you have a tach adapter for analogue tach :)
