Greddy TT Instructions?
canadianbacon
Extra Crispy
Dec 10, 2005
226
Coquitlam, BC
Just received from Japan and there is no instructions in English! F***!:aigo: Looked at Geddy website and server is down. Does anybody have a link and/or idea on how to install. I have the plug in harness, but I am not a wire guy. What plug? Checked the search area on this forum and nothing. Thanks for reading.:1zhelp:
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
^^^IIRC, it's back from the ignition. Take off the panels, slide underneath, and look back in a line from the ignition.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
just plug it inline with the ignition.once you take the panel under the steering column off you will see the plug.then the brown wire can hook to the wire on the e-brake for the kill switch.purple wire goes to speed sensor wire.once you have it working you can pick a mode.i can probably send you the direction's in an envelope,if you really need them.
