Greddy Speed Limiter Cut Question
one jay
us
1. your speedo is off, speed cut is 112mph (180 kmph)
2. you dont need a greddy speed cut defencer to go past 112, just cut the pink wire going into the ecu. doing this has no negative side effects (including engine light)
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
My speed cut is checked by GPS, which is 100% accurate as tested by 2 police radars. Also, you have to take into consideration different tire size and tread wear. I don't want to cut the pink wire because that will give me a check engine light and I don't want that. since it will drive me nuts. I don't like warning lights to be on for no reason. The SCD is the propper way to go above 112 MH
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
It will throw a CEL over your speed cut, not all the time. It is nice in that face, because it tells you to slow the fuck down :)
