greddy profec b spec II
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
Whats goingn on I got my greddy out of my car today which came with my car and what kind of wiring is required when you install this item? there is a spot on the back for for two plugs all it has is one a vaccum line. and this big bulky cork that looks like a power source that doesnt have a plug on it. What am i missing and what do i need?
IHI-RHC7
"The Boss"
Oregon
Please sober up, learn the english language a tad bit better, and rephrase your question.
I can't figure out what it is that your asking. I take it you purchased your supra, and it included a loose greddy profec B spec II, with no harness, no wiring, and no manual.
Is this correct?
Perhaps the wiring for the "plugs" you refer to is lurking behind the glovebox as maybe the previous owner had the profec installed, and then removed it prior to selling the vehicle, and then through it back in at the last moment.
Perhaps what you have is something that should be sold to the sad owner of a honda, and you should purchase a new boost controller, and have it professionally installed.
The big bulky cork that you speak of, does it have multiple colored wires in it?
Do you have a boost control selendoid for the profec? You'll need one, as well as a wiring harness if the "big bulky cork" only has a few wires in it.
Hope this helps, please clarify anything that I got wrong..
-Jake
gixxer750
2jzget comingsoon!
Mississippi
I believe the solenoid and the harness would cost almost as much as buying a new boost controller.....My greddy profec b spec 2 has two harnesses, a boost control valve, and a vacum line as well as a filter in the line.
huntin5L
Niles, IL
yeah i second that...sell it on ebay to some shmoe and buy yourself a new one. I like my spec 2, but i would of rather gone with a blitz sbc-idIII
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
sorry about the spelling errors, i actually only need to get the ignition harness, and hook up a manual switch to turn on the profec other than that its all good...
