Ok so i was reading the manual for the Profec B and i have it set up correctly.
The car has GReddy TD06H-20G Turbo, Tanabe SHM, GReddy Type S BOV. Thats it for mods.
When i went out to tune the boost, even on the min setting it would still boost past 8psi.
Heres how its set up (I did not set up the Boost Controller it was on the car when i bought it)
For the pins on the back. 4 is up, 3 is down, 2 is up, 1 is down
The hose im holding in this picture is going to the IN inlet on the solenoid box. The OUT inlet is going to the wastegate.
Should this boost controller be able to turn the boost on my turbo down below 8psi?
Thanks
~JDMMA70
Thanks
~JDMMA70
