Greddy emanage blue. Thoughts?
JISupra88
24
Illinois
Been doing some reading and not really finding too much support for the EMB (probably cause there are better options) but i have one laying around that has the main harness and injector harness that i was planning to use to tune my subaru ej22 but decided to build up the supra.
found some useful links though:
http://www.supraforums.com.au/forum/car-audio-electrics/40873-emange-wiring-7mgte-how.html
http://www3.sympatico.ca/zazzn/pics/emanage/
just wondering from people who have actually used the EMB how hard was it to get it running?
SideWinderGX
733
Wasn't hard at all to get running, it was a nice little unit for what it did. Allowed me to easily tune out high/low spots in the AFR map, and there's other EMB programs tha will allow you to make a run and log your AFR, which you can use to go back and modify your map.
I never ended up hooking up the injectors directly or the ignition, just piggybacked onto the signals.
JISupra88
24
Illinois
so w/o hooking up the injectors/ignition from the EMB, you were able to tune the car decently? definitely good news
so im assuming hooking up the injectors would just allow for more fine tuning
