Greddy BCC questions
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm thinking about buying a new Greddy BCC from one of the members. he said its for an mr2 sw20 or something but i have a 1j. will it work? is there anything else i could use to fix the boost cut and fuel cut besides fcd and bcc? i heard using a s-afc II will fix the fuel cut but it doesn't seem likely, will it work as i was told?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
my buddy put MKIV 550's MKIV cams and a walbro in his car and installed and SAFC II and his boost cut and fuel cut went away
still has speed cut tho LOLOL
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
tissimo said:
greddy does
http://www.greddy.com/img/PHP/products/pdf/683.pdf
find your pins (not hard, hint look at the afc wiring)
yes a bcc isn't needed.. get an afc and tune the car.. if you hit fuel cut you need more injector.. plain and simple
I think a BCC is needed. I have 550's, SAFC-II , and tuned, but still hit cut.....
BTW: where would the BCC be wired in? After or before the SAFC???
