got to see my taken apart motor today
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Well, I stopped by the shop where my supra is having it's head gasket done. Got to see my motor stripped down to the block... Head gasket was fubard (almost all cylinders were leaking) and it was broken at cylinder #1 and #6... otherwise it was in decent shape... I could see coolant pooled in cylinder #1 and thats about it... it looks great tho, really clean and no scratches or anything... It had $6000 put into the motor rebuild 8 years ago (40,000km ago) so I'm guessing it had new pistons and had the cylinders bored out or something, because it looked brand new... It was great to see, looked brand new :icon_bigg ... So I'm feeling great about my car now, once the head gasket is put in (it's a combination one or something, I guess it's similar to factory)... and told them to torque the head bolts to 80ft/lbs using lube rather than oil... so I'm going back there on monday to see the progress, they are sending the head to get machined monday morning and should get it back monday afternoon.
Everything soundin' ok? Anything else I should check with the mechanics?
Make sure they dump the Oil and refill BEFORE they crank it a single time as that coolany pooled in the cylinder will leak by the rings into the pan and WILL kill your bearings in minutes!
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
ya, they are a really good shop, very knowledgable, I'm sure they will do that... but I will remind them when I get there (hopefully I'll be there before they get the head back together)... Thanks!
