anyways just got done swapping in the jdm 7mgte...started right up w/ no problem...my Q is...Why is my upper radiator hose pinched like its sucking...is it my radiator cap?, water pump? anyone plz help
mastergrader007;1333798 said:mine did the exact same thing. turns out my thermostat was cooked. put a new one in and good to go.
Jokervrs;1333824 said:you mind telling me where you got your motor? i was thinking about getting one here
http://www.tigerjapanese.com/index....facturer_id=0&option=com_virtuemart&Itemid=26
theKnifeArtist;1333595 said:your title is not helping you get any help.
pinched only when running?
have the car cold, take the cap off, run it like that, see what happens until it warms up.
Skadaloz;1333982 said:lock it up...fixed the problem...it was the thermostat stuck close
