Got a blown turbo :(
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
this sux. i got the exhaust finished last night and the turbo is blown
at idle at traffic lights it just BILLOWS smoke like you wouldn't believe.....
this sux
The Reaper
Jan 10, 2006
1,909
Florida
hahahah yea except i just dumped EVERY penny i had into the swap.......how bad is it to drive it on blown turbo seals??
Supracentral
10
That smoke is oil. That oil is going out your exhaust instead of staying in the motor doing it's job.
What do you think?
The Reaper
Jan 10, 2006
1,909
Florida
well i have a road trip this weekend so i guess i'll just continue to pour oil in the engine then
i have no other car and im not a baller so i can't rent a car for the weekend
so i have no choice i guess
scottiedawg66
Bay Area Ca
I had the exact thing happen, my seals were bad from day 1 with my clip. I watched oil consumption and oddly enough I only had to add about half a quart every 3000 miles which was all i drove my car even though i had alot fo smoke at idle. Just be mindful and save your money. 935 has reasonable turbo kits. Good luck man.
~scott
The Reaper
Jan 10, 2006
1,909
Florida
i can't cancel my road trip its a family members Wedding on my wife's side and my wife is IN the wedding we can't just CANCEL
i guess i'll just watch the oil level
Supracentral
10
The Reaper said:
yea man when theres a nice breeze its like a line of thin smoke all the way across the road LOL
If you are sure the turbo is blown, do the following:
Wire the wastegate wide open.
Disconnect the oil feed line and cap the port at the block.
No smoke, no boost, no problem.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
That's interesting...now you will be 1JZ-GE...with no turbo. Hey if the engine still runs without it and no problem, why not ! this way you can still drive the car till money becomes available for your next turbo.
Supracentral
10
The car will perform like a Volvo 740, but it will run fine.
tissimo
Stock is boring :(
Melbourne, FL
the seal is leaking, the turbo isn't dead.. just ride it out.. its not too bad, just check the oil...
we'll try one of mine, maybe one of those is good, lol..
I have a question.. reading Jdubs post in the oil section.. maybe get some of that oil that has extra ester in it to swell the seal and maybe help it seal up a little more?
jdub said:
Ester makes seals swell and counteracts the effect of the PAO.
http://www.supramania.com/forums/showpost.php?p=540866&postcount=5
The Reaper
Jan 10, 2006
1,909
Florida
so you have wire open both wg's cause there are two actuators
tissimo:: they have that stuff??? where to get? is it JUST motor oil or can i get something that only swells the seal???
