Good Clutch for between 350 to 450 HP
Cravin Boost
MMMM Smells like coolant
Nov 8, 2005
170
Eugene OR
I did do a search and did not see where anybody asked this question. I am about to do an engine swap and I have about $300.00 I can afford to replace the current OEM toyota clutch. I want to put something in that will allow a bit of building before it needs to be replaced.
I am getting a JDM motor putting in a Titam 1.4 MHG ARP studs Downpipe with exaust no cats in the system. looking for opinions and experiances your willing to share.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I went with an RPS Maxx series stgIII clutch for my new setup which I'm hopin to be hitting 450hp...
PorterzSupra
703
Hebron CT
XTD 6 puck goes for about $250 holds around 450+ HP works great with smooth engaugement!! I had the F1 it was really ruff but this one works great!!
aye mate
Hiatus over.
Maryland
I like my spec stage 2. Rated to 460ft.lbs. Spec also has the Stage 2+ and the Stage 3 which is rated to 520ft.Lbs.
MKIIINA
Destroyer of Turbos
Plano, TX
i have the spec 3 and it works pretty well. the clutch actually seems to grab harder now that i have a few drag passes on it. when its warm though it can be a touch hard to engage smoothly.
casper35404
165
Tuscaloosa, AL
Spec stage 3. In full agreement that when it's warm it's hard to engage smoothly. I tried the stage 2+, but it vibrated a lot. I don't know if it was the flexplate or the clutch, but my shop is probably not going to put one in another MKIII. Besides, the stage 3 is cheaper and holds more power. I wonder why.....hmmmm
mkIIIman089
Ohio
I have spec stage 2 in my car so I would be inclined to reccomend a stage 3 for you to add a little bit of buffer on the torque range.
westonboege
134
providence RI
man... alot of spec clutch users on here...
I have the spec stage 1... clutch is great but i should have thought ahead of time... got a new turbo going on the car... and its gonna be at 400-450hp... clutch is only rated to 400ftlbs... should be ok for a while... probably only push high 300's to save the clutch a little...
prepare for the future...
Disc type= smoother progressive engagement more tolerant of being slipped
Puck type= On off capable of holding a good deal more TQ than a full face due to higher force per sq inch of material don't like to be slipped for extended periods .
Eriol
Indianapolis
IJ: sweet, thanks. So if I could find a disc type clutch like the RPS stage 2 or Spec stage 2+ that could hold 500+ lb-ft of torque, you think that would be the best way to go for a car that will spend most of its life on the street?
(I'm looking at the Clutchnet ones Al linked right now... very nice prices!)
Not really sure what's available in full face for that TQ rating but I'd guess anything that strong will be a puck disc!
I run a twin disc solid centre full face ceramic here and while it can be a little tricky to drive it never slips!
Eriol
Indianapolis
Well, according to MVP's website the RPS stage 2 is rated for 575 lb-ft, and the Spec stage 2+ is rated for "more than 460". (both are disc-type, going by MVP's website)
Unfortunately, that Clutchnet website doesn't list any torque specs for any of their clutches... I guess I'll have to actually call them, or something.
Eriol
Indianapolis
The stage 3 seems to come in both disc and a 4-puck version. MVP says it's good for daily driving. *shrug*
Found Spec's website -- the Stage 2+ can hold 500 lb-ft of torque, and the 3 can hold 520. The 3 is also slighly cheaper. :dunno:
I need to find people with all the clutches I'm thinking about getting, and convince all of them to let me drive their cars... somehow... :)
aye mate
Hiatus over.
Maryland
IJ. said:
"more than 460" is a worry 461?
Seems the guys are liking the spec-3 is that a full face?
My stage 2 is a full face and the 3 is a 6 puck.
The 2+ has kevlar(stage 2) on one side and stage 3 material on the other side.
