I purcahsed this car in October 2008, from a private seller across town. It's a '91 Australian sold MA71. When I got it, it was stock besides a 3inch dump pipe and a turbosmart dual stage boost controller.
The first thing I did was replace the stock BOV (which was leaking) to a HKS SSQV. I had a hard pipe made up for it to bolt to and spent hours trying to find a recurculating fitting.
A few months later, the power steering pressure hose split, so I replaced that with a driftmotion braided line. I also replaced the stock V/H cooler with a spare 7M oil cooler and replaced all other lines with braided lines. (Thread can be found here: http://www.supramania.com/forums/showthread.php?t=95798)
I then managed to get my hands on a HKS EVC III electonic boost controller and fitted that.
In between all that, its seen serveral services, plently of hills driving and a trackday.
It's current situation isn't to healthy. Thursday arvo I was carrying out compression tests to a mates car and decided that I may as well do another one on mine as it hadn't been done since I got it.
Numbers were all between 105-110psi on a dry compression test and 110-115psi on a wet, besides cylinder 1, which could only manage 80psi on a wet test.
Further tests last night and today with a leak tester has confirmed there is a rather large leaking coming from the intake valves of cylinder 1. There is also slight leaking from cylinders 2,3 and 4, however they are nothing compared to cylinder number 1.
At the moment, the car just has the valve covers off, but my next plan of attack is to get the turbo/turbo manifold and intake manifold off and carry out the tests again to pin point all the leaks properly.
Here are a few photos of the car over the year...
And this is how she is at the moment...
This build thread will run through the fixing of this motor and then the continual building of the car afterwards. I'll hopefully do both major and minor updates, along with any problems I come across in hope that someone else may have an idea or solution to it.
Hope you enjoy reading,
Cheers,
Dale
Cheers,
Dale
