I have a 89 supra N/A 5,speed that im lookin to make turbo , ive herd the good & the bad , on my 3rd engine, 1st one i tore apart the crank & pulley insted of gettin a new crank i got a used engine , cracked the head gasket on the second engine , n the 3rd 1s goin pretty dam good , she pulls nice from 2400 rpms to 4700 then it just laggs up to 6400 n hits rev limiter at 6700 rpms , a late spoolin turbo n a head gasket n would be great 4 my n/a :naughty:
I think if i run a apexi safc & a aem wideband uego controller to over ride the n/a ecu , a greddy/trust type manifold a 50trim turbo wth a t/4 exhuast manifold flange & a 3 inch v-band down pipe flange & 3 inch compressor intake, custom 3 inch mandrel bend down pipe & turbo elbow , drill a hole in the elbow n weld in a bolt that fits the screw for the bosch o2 on the wideband system, A 7mgte maf air with a k&n fipk filter ......
Now down to the block , im comming up on around 100k miles soo i wanna replace the head gasket & rebuild the cylnder head & put back on with arp head studs !!! be4 i put the head back on i was thinking if i should go with Nippon forged pistons , n eagle h rods , if i run the pistons ill have a lower compression & be able to run more boost , but if i stay with the pistons i have now i can only run 7-9 lbs a boost but 7-9 lbs on a n/a motor is like 14-16 on a turbo motor .........
Wanna hear what the pro's at supramania think !!!! hit me back .late.
MKIIIChucky
MKIIIChucky
