Going to be rebuilding my diff soon, do I have everything for the rebuild?
steveyblack
529
Nj
Hey all I just want to do a quick parts check and tool check before I begin ripping into my diff.
Rebuild Kit: This kit covers all the bearings and seals as far as I can see, anyone have any experience with this kit?
http://www.jawsgear.com/Installatio...KitMasterComplete/MK_TSUPRA/product_info.html
Solid Pinon Bearing Spacer: I dont want to use the crush washer and would rather have a solid spacer. I have play in the pinion bearing (the companion flange can be moved .5" in either L/R U/D, a little in/out play).
http://www.weirperformance.com/solidpinionspacerkits.html
Shim kit/Spring kit: I basically DD the car, I want a tighter diff with very little chatter, Im going to shoot for the lower end of the spectrum when it comes to break away torque (75-80ft*lb).
http://www.weirperformance.com/maxgriplsdkits.html
As for tools. I have a 25 ton press (might be a 20 actually), dial gauges, calipers and torque wrenches. Do I need any SST's for the rebuild or can most things be done without them? I just want to hear your guys experiences since I have never rebuilt a diff.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
You'll need an sst to get the axles out.
They'll loan you the puller at autozone for free. As for the solid pinion spacer, it will take a couple tries to get the fitment right.
