Ok, for those that know, I got into a crash about a month ago ( the post is easy to find, I don't post a lot).
Anyway I bought a shell car from ma71supraturbo in December, and I finally finished porting everything good from my crashed MKIII into the shell car, and now it's finally running::w00t::. The engine's operating perfectly, but I'm getting code 61 (Speed sensor 02 error) from the ECT.
I just checked inside the extension housing and the rotor for the speed sensor looks fine but the speed sensor itself looks a little beat up (I'll post the pic tommorow). I swapped the beat up looking speed sensor with one I knew to work, and it did for about 10mins despite still giving a code 61, but now it's back to square one.
I found out I was three quarts short when filling up the tranny (for some reason I was thinking of engine oil specs when I did it the first time), so after filling it up to specs I ran it in drive to fill the torque converter and get it to upshift, but I still haven't made any progress.
I also checked both sets of harness wires with the multimeter for signal continuity, both the tranny and the engine harness are fine.
The only things left I can think of are that I have a bad ECT/Speed Sensor/both or that my shift cable is adjusted so horrifically that the tranny refuses to upshift!:cry:
If anyone has any ideas let me know!
