Go big or go home build!!
tractionless
Crandall, Georgia, United States
OK folks, Oct 2010 I got my 1st Supra. A 90 Targa. Already with a swap. I got it from Nalleywhacker here on SM.
His build thread- http://www.supramania.com/forums/sh...acker-s-build-thingy.&highlight=nalleywhacker
When i got the car I drove it for a few weeks then soon put on a boost controller and turned it up to 19lbs. Drove for a while then pump started failing, dropped in a walbro then headed to the dyno, Car made 391whp and 398ft lbs. Around feb2011 the ebay single decided to blow the seals. ....and it begins
I bought a precision 6765 Billet twin scroll, 1.15 backhalf. also ordered BC 272s and supporting springs. Also got their valves, +2mm and +1.5mm ....
Had the head worked, 3 angle full port and polished. While waiting on the head I decided to go all out so I tore done the complete engine 2-0D1F4554-380477-800.jpgSupra@.jpg
tractionless
Come to find out, wiseco as well as myself missed a small detail, they sold me 2j pistons. they will work just fine as pictured, I bored my block out, however since the 1j has a shorter stroke than the 2j it will make my motor lower compression. 7.5:1 is what i figured with all the measurments. So these have to come back out. ANyone wanna buy some 2j pistons? lol
tractionless
Long block.jpgOK- Block was decked, head was shaved, Oil clearances checked, block bored .40,
Acl Race bearings, Had to order an extra set to get the right oil clearances. I have an extra set of acl race bearings standard size 1j/2j forsale
Forged Billet Carrillo Rods
Cp Pistons by Carrillo
Toyota Oem oil pump
2j waterpump
ac competion stage 4 clutch and lightweight flywheel
Rotating assembly fully balanced including clucth and flywheel
Billet ALUMINUM Pulleys
tractionless
Found my old dyno sheets,
Mods at the time of dyno
Completely stock 1jz aside from a driftmotion manifold with a ebay single
Walbro 255'
boost controller turned to 19lbs
full 3" Exhaust
ebay front mount
mk4 550s
Safc Neo
hks FCD
Heres the best one
