Glove box help please
turboguy327
63
Rochester ny
My glove box is stuck in valet mode or whatever you want to call it. I cant open my glove box without the key and it drives me nuts. How can I make it open with the button and not need to use the key every time?? I dont have an owners manual and it only turns counter clockwise from 12 o clock to 9 o clock. Should it turn both ways??
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
mine will either turn clockwise or counterclockwise from key vertical position. i just had to play around with mine for a while to get it to unlock correctly.
the walrus
17
Guys......mine was exactly the same way and it drove me nuts.
The solution: 1 quick squirt of WD40 inside the glovebox keyhole. This loosened up everything and now it works perfectly!
Justin
Kota
105
michigan
mine started doing that, now it doesnt work at all. i pulled all my stuff out from that backside but im not sure what to do about it. parts cars arent easy to find here
Justin
Best is graphite spray (made for locks)
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
The Supramania classifieds is full of parts cars, and a glove box won't cost you too much usually. If it is grey, I have a working lock mechanism I'd sell for $10 shipped.
jugodegolf
Phoenix,AZ, United States
For those that the WD40/Graphite don't solve the problem. It's probably broken plastic tab in the locking mechanism.
You can get a hacksaw blade. Pull the glove box down a little so you can see the bracket. Cut the bracket BE CAREFULL. Go to any junkyard get replacement or order new one from toyota. Either way you won't have to change out the whole glove box. Used to have the pics somewhere. Doh!!:3d_frown:
Scott good luck finding a shadow grey glove box.:evil2:
