getting real pissed off. correct allen wrench size for arp studs?
cypher02xd
This newb owns you
Oct 28, 2006
23
Maryland
i tried 5mm and it seems to slip when i try to torque down the bolts so what size is it? or do i just need to fight with it to get it to work correctly? also, i think the first head bolt you torque might be messed up. advice on what to do with that.
lagged
1991 1JZ
new rochelle
read the instructions that came with the set.
youre supposed to thread in the studs FINGER TIGHT only, then tighten the nuts in the CORRECT SEQUENCE. make sure you go to the TSRM for the correct torquing sequence on the head.
BoostedFloto
154
Tampa, FL
the problem with "finger tight" is sometimes its NOT right. a lot of blocks have old dirty threads... so you HAVE to use an allen key to put the studs in a little further and make sure they are all even...
finger tight just doesnt work most of the time.
supra90turbo
shaeff is FTMFW!
MA, 01440
Finger tight will work if you CLEAN THE THREADS!
You're supposed to chase all threads before installing new studs. Clean the head bolt holes thoroughly afterwards, and blow out with compressed air.
Lagged: lol... you're welcome indeed... sheesh!
CBLEGUY
Organic90T "Growin Roots"
Nov 24, 2006
127
Cape Coral, Florida
I agree, finger tight on a perfect block with perfect threads. I know I have had to use an allen before.
lagged
1991 1JZ
new rochelle
the right way to do it is to first clean all the threads. finger tight IS the right way to do it, not sometimes, not half the time, all of the time.
supra90turbo
shaeff is FTMFW!
MA, 01440
Correct yet again, lagged. I must also add that if it's not going in finger tight, then back it out and thoroughly clean the threads. If you have to use an allen wrench to really tighten it in there, you run the risk of cracking the block.
