first let me give a quick intro. im not new to cars or turbos. I've built and tuned a turbo gsr, and was in the process of turboing a s14 but lefts face it, a stock turbo motor is a much better platform.
I came across a 88 turbo supra with a freshly installed jdm 7mgte, figured its a good base. As you wouldve guessed by the sn, i dont like spending money on anything i don't have to, not that i have much money to spend anyways so i'd liek to make this as fast as possible with simple/cheap mods.
well... guess that wasnt so quick
onto my questions. i think it was here i read that a stock afm measures about 2.5v at idle. does that sound right? thats pretty high so i'll assume max voltage is at least 5v. since its already halfway at idle, could voltage be dropped at the signal to ecu, then the fuel corrected by afc? that would allow more airflow before fc while still being metered, right? unlike a fcd, bcc, safc, etc. which tricks your ecu into thinking theres less airflow, therefore less fuel will be injected. anyone tried it
btw, is there a voltage to rpm table for fuel cut or is it a certain voltage no matter what rpm?
