Gauges
mk34lyf
65
florida
I need to replace the stock gauges on the dash (speedo, tech, fuel lvl., and temp). Where can I find racing gauges that light up that come in those four types. I need a boost and air/fuel ratio gauge too. I want them all to match. I don;t want exhaust temp, trans temp, etc. I need that temp meter that they have on the stock car. (Is pyrometer and the stok temp the same?) I also need a 10k rpm tach and 200 mph speedo. Anyone find these?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
If your going to get an air/fuel gauge then you have to get a real Wideband like an AEM Uego not an autometer narrowband. Difference is narrowband only reads rich or lean essentially with a sweeping light bar. A wideband has a wider voltage range so it can actually show exactly how rich or lean your car is with numbers.
Autometer doesnt make a wideband so your going to have to have an odd ball gauge. There are lots of widebands out there, just search google for wideband gauges.
