gauge pillar
If its a wideband a/f gauge i would get something like oil temp or egt. Or if you want to put one of those in the cluster and put boost in the piller. If its a narrow band light show gauge ditch it and get a real wide band with wide band o2 sensor.
Personally i will be putting new oil press, water temp, and boost in the stock locations with more accurate gauges and then have oil temp and egt in the piller as my wideband is on the steering column cover.
Albert
May 13, 2009
1,710
Tempe, AZ
I took my stock coolant gauge out, replaced it with AFR read out. took stock boost Gauge out replaced it with NA Volt meter.
And Aftermarket Boost, and coolant are in my 2 gauge pod pillar.
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Like this albert :)
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
My car was originally an NA. I left the voltmeter in, and used the pillar pod for boost and an aftermarket coolant temp. If I had a wideband, I'd use that instead of the coolant temp.
