gauge light wiring
hornet7288
260
Savannah, GA
I have the lotek gauge pod with a autometer II ultralite oil pressure and boost gauge that I am going to use once I swap the engine. I have a good ground for these and have already hooked that up. Where is a good place to tie into for the power source? Thanks.
hornet7288
260
Savannah, GA
I tried this and blew a fuse and like a noob added a larger fuse to it and then burned out the rheostat. I got a new rheostat and got the stock gauge lights working again. I forgot until tonight that the previous owner wired up some retarded rope lights that are on this same circuit wired into the cig lighter running light deal. These probably draw a good bit of power so I feel that once I take these out and wire the gauge lights to this same circuit it should work just fine without popping the fuse. The autometer ultra lite II's are LED so I feel like it would draw less power than your regular lightbulb, but I am not sure. I am an electrical noob.
radiod
1,342
Abbotsford, BC
Yeah, there's no way gauges will pull enough to blow that fuse by themself. Especially if you're not using the lighter.
IBoughtASupra
4,455
Queens, NY
I wire them to the accessory on the radio. It works fine and no blow fuses. I removed a bolt, put a fitting on the end of a 12 gauge ground wire, cleaned the surface and used that as my ground for all three of my Prosport gauges. Temperature, Wideband and Boost.
