After a motor swap, got everything hooked up and car starts and runs like a champ. Only problem is the only things that work on my cluster are the tach and gas gauge. I get readings from nothing else and I am thowing a code 11 engine light. The cluster worked just fine prior to engine swap. Any insight on what could be the cause of this or any troubleshooting tips. Any and all help is much appreciated. Thanks in advance.
