Well Im not sure if the entire gauge cluster I bought is "bad" or something else is going on. I replaced the cluster because the previous owner had rev. glow faces on them and I think they looked like ass. Now none of the gauges are working/reading. The only thing that works is the back lighting.
Also one other thing, this has also killed my check engine. (no way to check for codes, ect. on my fresh engine) I have swaped bulbs with the "door open" one and still nothing so the bulb is good. Door open light dose work and comes on when it should.
Info on car: 89 turbo, 5-speed, tems,
Cluster I bought I am guessing from a 90+ because it has a air bag light.
What I have done already: The fuse is good but still replaced it. There is 12vDC on the bottom side of the fuse and the top side has continuity to the yellow wire on the blue plug on the cluster. The m1 body plug is together and tight. Also there is 12 vDC switch to the yellow wire.
What else should I check? Source another cluster
