Gather up a few things, Need INFO PLEASE
Suprastic
727
Manitoba
Im currently shopping for some 1JZ parts so i can commence on the swap. I what parts are needed, however im stumped on a few things.
I found a 1jz engine complet ewith auto trans for $900. It includes turbo and everything else, except ignitor and has a cut harness.
Now I want to stay auto so here are my q's.
Is the 1jz auto trans a direct replacement?
Im currently NA, do i have to buy a turbo auto DS?
What else should i know about my 87 NA auto to 1jz auto swap?
Your help is greatly appreciated
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
you will need the BIC motormounts or swap to an 89+ crossmember
its gonna be fun trying to find a 1JZ ignitor....any pics of the engine set like the cut harness you might be missing more than you think.
Suprastic
727
Manitoba
Ive already contacted the seller and know what i need. Ive also sourced the iginitor and Map sensor. Im also aware of the BIC mounts.
WHAT i NEED to know is about the auto trans. Is it a direct swap from the 1jz into the ma70 chassis. what about mounts, driveshaft and diff.
OneJoeZee
Retired Post Whore
aboard the Argama
where did you find a complete 1JZ engine set that is going to ONLY need an ignitor and a harness?
Sounds fishy. My gut tells me this isn't as good a deal as it sounds.
Suprastic
727
Manitoba
well i t need the fans, ic, ic piping to. since im goint aftermarket ont he fans, ic, and piping, most of that is irrelivant to me. I knwo what parts are missing, and what needed. Its not a short list.
All i want to know about is the auto trans. If i dont like what i hear, i will buy the clip they re selling for $2800 and have everything i need, including pparts for a 5 spd swap. Unsure about pedals and clutch master cylander of they are the same or not.
The Reaper
Jan 10, 2006
1,909
Florida
it should all go in im not too sure but it sounds like a direct swap...im not a fan of autos so i never really read up on it...
are you getting this set from the Osaka guys?
