GASKET question "not a head gasket dont worry" lol
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
Bethpage, New York, United States
Changing the valve cover gaskets because theyre leaking..My question is you all know that annoying center gasket thing prob to well "Most say its useless" ?? I want to remove it and put some Ultra grey under it because my plugs were swimming in oil pretty bad.
Problem is Those hexes with elephantitis what size are they? biggest I see around in most places is 10mm?? I got a 12mm from sears and they said that was the biggest they have...looks like it could be a 13 or 14mm?? If you know what size it is where could I get it?
The Toyota manual says the dreaded "SST" but in the sst index it just says hexagon tool...Locall toyota was no help either they told me that toyota doesnt sell special service tools and to go to pepboys...lol I hate pepboys
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
You could always buy tools with cash, from the pro trucks (ie: snap-on, Mac) if you see one parked at a repair shop.
14mm x 3/8 dr socket.
Most auto parts stores, and Lowe's, Ace, Home Depot, etc.
By the way....that center gasket (not really a gasket) does not prevent any oil leakage. Its ONLY purpose is to help keep dirt and debri out of the spark plug holes.
When it was a new car, and with factory plug wires that fit nice and snug, it did a good job. My after-market wires don't seal tight on it, so water could get in.
If you ever wash your motor with water (which I don't recommend), it will get down in there anyway and short the spark out, and cause a miss-fire.:icon_sad:
Some people leave it off, but I don't recommend that, either.
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
you taking about the spark plug valley?
cheap easiest way
Find a bolt that fits in the hole. and vise grips
FTW
Josh Sulsberger
Down for whatever
Apr 9, 2005
69
Milwaukee, WI
I used three 7mm allens together, fits nice. Check out the pics for some illustration of how I did it...
First pic has the wrenches in a 14mm socket, second is how they should be configured.
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
www.ArizonaPerformance.com
use one of these their called a coupling nut
go to www.Mcmaster.com look for this one 90565A320 they are 9/16's inch hex which is very close to 14mm then you can use a conventional socket on it.
You dont need the cover at all. If you have an air compressor and a nozzel just spray a little brake cleaner in there and sop up what you can with a strong paper shop towel. I wrap one around an old screw driver and dig at the dirty spots and mine looks clean as new. Blow the compressed air in there and all the debris and dirt will come flying out. Use a fresh shop towel if your concerned with the dirt landing on your clean motor. And make sure to protect your eyes.
just ditch that piece of crap cover.
DETONATION666
DECEPTICON MK3
Oct 29, 2006
333
You guys kick ass!! this is def the best MK3 source yet!
"I didnt want to be an idiot noob and not search 1st but when I did I couldnt find any threads about this hex"
Its like a couple of stupid little things that are keeping me from getting her on the road...you guys know the drill
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That's fucking hilarious! I'm glad it works for you though ;). +1 for compromising!
