So I was about to go out, and when i went to fill up the tank, the gas door wouldnt open... :cry: So i've been doing some research, but correct me if i'm wrong. People generally say that it has a latch, not a magnetic mechanism. Also I hear that if you pop off the panel on the passenger side in the trunk, you can reach through and undo the latch. ?? Would that be the same panel as the one to gain access to the antenne motor? Any ideas or suggestions would be much appreciated as I would rather like to drive her again :icon_bigg
