Hi guys!
So, I have a problem with my '87. I went to get gas today (thankfully close to home). I pulled up on the gas lever, and the door wouldn't open. I pulled the hell out of it, jiggled it, yanked and applied steady pressure- I even got someone to hold a key prying up on the door while I pulled that lever- no dice.
I had to drive it home, jam a screw driver into the gap and pop it open manually. I removed the plastic piece that latches it closed until I can get this fixed. I own a 1987 Supra TSRM, but there's absolutely nothing in that book about this lever, or the cable it connects to.
My questions:
1. Has anyone had this problem before/heard of it before? I searched the forums and came up blank. Just curious. :3
2. Is there a way to tighten that cable somehow? If so, is it by the lever (under the seat), or at the actual gas door? If it's at the gas door, what panels need to be removed to get to it?
3. As it's been getting more and more steadily loose, I think it's entirely possible the cable is fraying somewhere along the line. What path does that cable take to get from that lever to the gas door?
Thanks for your help in advance- I wish the TSRM had something to clue me in on this one.
My questions:
