Gallon of water in my wheel well
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
I have what looks like to be a gallon or so in my drivers side wheel well that is just chillin. It's not really draining. There is no hole from the tire side, just the two from the wing mounts. Is there something i can get to fix this? I want to fix it before it gets rusty.
BTW, i already searched for "water".
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
JustAnotherVictim said:
Pull the plugs under the tire.
Then fix your seals.
But yeah, i have hatch seal leakage, but none of that gets in the wheel well.
I want to do something that stops it from filling or getting wet so drilling a drainhole is out of the question unless there is already one there.
ridah
Thats rice
Apr 4, 2005
Beverly Hills
Mine was leaking from the blinkers in the trim on the sides of the car. If thats where it's coming from take out your blinker put a little silicone on it and reinstall it.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I'm pretty sure there is a rubber grommet down there, possibly on the outside of the well. Either pull that, or unscrew the rear bumper cover support, and the water should come out of those holes.
I had water in both rear wells, as well as the driver side main support beam - I just found out why yesterday....grommets missing under the car FTL.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
I just ordered a hatch seal and both taillight seals from toyota for $100 plus tax. Should get here by thurs. In the meanitme, i'll check the side markers and rubber grommet.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
ForcedTorque said:
There is a drain hole! Look under the car in that area, and you should see it. Poke a screwdriver through from down there, and prepare to get wet.
Will do. For now i just sponged up the water. Thx pplz.
mkIIIman089
Ohio
WTF... this is crazy. You guys should not be giving advice. Drill a hole!?
There is a rubber plug at the lowest point (novel idea!) of that cavity. Just pop that out (goes out the bottom) and it will drain.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Yeah, i was def not going to drill a hole.
Ckanderson
2,644
The beach
good. You would be suprised at what people post on here.....
drilling a hole in the body to fix a leaking gasket problem is NOT what you should do. haha.
