specs:
7mgte, 46 trim ct26, stock fuel system, 2 1/2 exhaust, intake
started off with code 11 (random stalling)
moved some grounds and added a ground from the battery to chassis (was missing
code 11 fixed
fuel pump problem (more stalling)
then got intermittent power supply to fuel pump... sometimes it has power sometimes it don't
jumped ign feed to fuel pump wire
i believe fuel pump supply now fixed
new problem
driving fine, stop at lights or crossing etc
go to accelerate and car just stalls (doesn't happen every time... probly once every trip)
have the car idling in the driveway... rev it a bit and hold it... it pops/backfires (i'm guessing it's running quite rich at idle, thinking of sticking in slightly colder plug to help with burning)
rev it quite a bit up to 4.5k and off and back up etc etc
leave it come back to idle... sitting there for about 30-60 seconds... then just out of the blue revs start slowing down to 400rpm and then STALL
no codes
when running it runs mint!
just randomly stalls :s
any ideas to throw around?
Thanks
code 11 fixed
new problem
no codes
Thanks
