Fuse Block module
Kris
cedar hill, tx
I can't get the 100A fuse out of the fuse block. My understanding is that the fuse is held in with screws in a module that must be unclipped from the main fuse block. The retaining clip for this module is beside the fuse, but how do I release it?
Satan
Tampa
Are you talkin about the block by the battery? I have a couple of harnesses out and can snap a pic.
Let me know.
Kris
cedar hill, tx
Yes. The main fuse block is next to the battery.
I want to remove the 100A fuse. Evidently its held in place with a couple of screws. To access the screws, its necessary to first release a retaining clip that holds the 100A fuse module in the fuse block. I can see the clip, but dont know how to release it without tearing it up (its molded plastic)
Satan
Tampa
To the front of thast fuse is a small clip (circled in 2nd pic). Use a small/tin flathead to push this little tab (arrow pointing to it in 1st pic)while pushing down on the fuse... comes out of the bottom of the plastic holder/assembly and has a bolt on both sides. Good luck!
