Full/good guide to 1jz swap
80er
9
DK
I tryed to look the forum but can't find anything....
It could be nice with a guide with info about witch parts i need and trouble i could run into...
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
http://www.supramania.com/forums/showthread.php?t=63
if you read through the jz section there should be a lot... things depend on if you get a front clip or just the engine, you'll need transmission, (r154) driveshaft, wiring harness, ecu, if you car is older than 89 you will need engine mount, 1jz bellhousing to name a few things... i think you will also need a diff power steering line and a different throttle cable,don't quolte me on those two though :p
80er
9
DK
Okey thanks
I got the frontcut....got the engine out...and considering to mount the CT12B turbo's but i dont know if they will fit ?
