I wanted to write here what i would have liked to have known before i jumped under the car.
Parts:
There are 2 rubber donuts holding up the muffler, 2 donuts behind it,
one of those non-donut rubber hangers just before the muffler,
2 more donuts before that,
And 2 more donuts up by the 2nd cat.
The bracket attached to the transmission uses m10×1.25 thread bolts
The heat shields all use standard 10mm bolts.
The O2 sensor studs were seized in the stock elbow, so i used m8x1.25 bolts on the new downpipe.
I was unable to pull the whole exhaust as one piece, and it was too awkward to crack off the cat bolts while in the installed position.
I first removed all but one of the donuts on the end, then i cracked off all 4 elbow to turbo nuts, letting it sit on the studs.
I then unbolted the bracket on the tramsmission to the downpipe.
Then slowly shifted the weight off the studs to the support bar underneath.
The middle of the exhaust was now low enough to comfortably use a rubber mallot and 2 wrenches to crack off the cat bolts.
After removing the muffler side, the downpipe side easily shifted out with the elbow still attached.
Im using an ebay downpipe and the driftmotion catback. I will update when its all back together
Parts:
