Clifton said:What's wrong with the stock sump? I guess it doesn't have bling. Stock ones work so good I took the sump out of a mkiii tank and put it in a carbed Z tank I also used the intank pump hanger and flange with a Walbro.
figgie said:huh?
the stock sump is not meant for dragging purposes.
Just think logically what happens to all that gasoline in the tank when you accelerate. That is why you need a sump
Clifton said:And you think a small box welded to the bottom of a tank is meant for dragging? Why because it has an AN fitting? There is a baffled sump in the stock tank. The fuel cannot exit it without going out the pickup. If it's good enough for my car that not only goes fast in a straight line but is also autocrossed(more G's than dragging)with R compound tires I don't see why it wouldn't be good for dragging. I'm pretty sure with my power to weight ratio I can accelerate as hard if not harder than any MKIII on this board and I have yet to have a fuel pick up problem. Try a welded on sump autocrossing with EFI and 1/4 tank.
figgie said:ahh ignorance
You seem reluctanct to understand the simple physics of why that "simple" little box actually aids in fueling and what it's SPECIFIC purpose is......
A fuel cell that is designed with autocrossing/roadracing in minds will not work well in a drag environment and vice versa. That is WHY the circle track folks actually sump the fuel tanks on the left hand side. Guess where all the gasoline accumalates and no amount of one way trap doors or anything else will keep that fuel in the stock sump area. Want to take a guess whee RCI intalls their fuel sumps on their fuel cell that are for drag racing? You have ONE guess
Of course am talking about a fuel cell but guess what. What works in a fuel cell works in the stock fuel tank too
Sumps are built with a purpose. The purpose of the STOCK sump is to keep fuel on the pickup area under street driving condition. Change the purpose of the car and the fuel tanks sump has to be changed accoridingly.
See all the purpose built fuel cells to see WORKING examples of what I state. Drag is ALWAYS towards the back, Circle track is always towards the left hand sid as they are always turning right Road racing have specific baffles + one way gates plus other confidential mechanism to always keep fuel going even when running on near empty.
Clifton said:You don't need it, even though you think you do. If someone wants to run an external pump and blingy sump hanging down with shiny fittings on there street car then that's different.
figgie said:blingy sump and external fuel sump.
hmm perhaps you also need some basic read comprehension 101. The MKIII sump baffle is far from "good" enough. It works but so does holding gasoline in a gallon of milk and feed the motor from their. No matter what your you closed mind seems to think, the sump does have a purpose hence my purpose built statements. If they didn't no aftermarket fuel cells would use them.. Capiche why I put fuel cell n my statement? For morons like yourself that don't read and much less comprehend what a fucking example is.
I am done with you.
Clifton said:Hmm, name calling. What are you 15? Nice representation of the way a mod should behave on a board. This is what happens when people don't agree with what you say?
My closed mine knows the MKIII setup works as I use it. I'm not saying that cells don't work. I'm just saying the Supra tank works and not just in a straight line.
Drag cells don't work for road racing or autoX. Circle track cells can work for drag racing but not for RR or autoX. Neither work well on the street if your car can handle. Again, back on the cell topic. The stock tank works great for everything. What part of that don't YOU understand. You say "far from good enough". Give an example. You have pick up problems in your car? I don't think so. If you do try running more than 3 gallons.
