IBoughtASupra;1680368 said:
Post ten, sarcasm when your the one asking for help is a :nono.
Didn't sound sarcastic to me. :dunno:
Sheesh, seems like these EGR/CC threads
always turn contentious without fail nowadays. It's understandable if the OP were not listening to sound advice (yes I agree, there are a lot of the past threads like this...), but I don't get that impression here.
Poboy, I tend to agree with Poodles and IBoughtASupra to a degree. At a minimum make sure you are
not venting fumes into the engine bay. If you do remove the CC, at least reroute the fuel tank vent line somewhere safe away from heat and any possibility of a spark. I have mine vented out the back right of the car, above the fuel tank and away from the exhaust. Though not as important (for safety), I also run a ~2-3 PSI check valve on this line to keep some pressure in the tank like stock.
That said, it really doesn't simplify things too much. It's a simple system as-is. I just have a FFIM without a ported vacuum source to run it off of, which is why mine is no longer there.
