Fuel setups for 2jz Mk3 Swap???
jdmk3
2jzmk3
Mar 28, 2006
78
Walnut, CA
Just wondering what fuel setup I should run on my 2jz mk3 swap in progress as far as injectors/lines/pumps etc.... I have a setup in mind but just want to see whats out there. My goal is around 600whp. Im goin' with a greddy t78 single...:1zhelp:
tissimo
Stock is boring :(
Melbourne, FL
yea go 2 wallbros and ~ 750cc injectors for your goals.. -10 to the front split to dual feed rail and fpr and stock return.. wil work great..
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
^^ quite overkill for a greddy t78 isnt it? its only a 67mm turbo IIRC.
edit, that turbo will also get you to where you want, just only on race gas. it made 600whp 650lb/ft through an auto on my friends set up.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Dual intank walbros, fuel lines, any aftermarket rail with 750cc injectors. Throw in a MAP ECU and you're done.
If you didn't buy the turbo already, check into a Precision PT72GTS. Probably cheaper, and will put you close to 600whp on pump gas, the T78 won't.
SD2JZA70
HardTunedMotorsports
San Marcos, CA
I would say for you goals run dual walbro's in tank, 10 feed split to two -8 dual feeding the rail with a -6 return, 1000 cc injectors, Aeromotive FPR and of course one of my custom 2J top feed fuel rails :icon_bigg
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
im still saying that 1000cc injectors will be WAY too big for his goals. a 600 whp goal on a greddy t78 (67mm) would require no larger than a 850cc injectors.
SD2JZA70
San Marcos, CA
They are a little large for 600 but they cost no more than 850's or 750's and typicaly people tend to want more power and end up upgrading anyway. Why not set the car up for more power and have room for more power in the future. Anything bigger than 1000cc might hurt driveability a little but 1000cc work great.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
disregard this if he is standalone
with the 1000 cc injectors he will be pulling so much fuel his timing will be greatly fucked, not to mention that the piggyback might not be able to handle such a large injector.
if he is standalone, then i wouldnt see a problem with the 1000s
SD2JZA70
San Marcos, CA
This is true. I would imagine that he would be at the very least running a VPC which could run the 1000's but he would be better off with the 750 or 850's if that is the case.
SD2JZA70
San Marcos, CA
Ric said:
you don't need a stand alone for 600whp.... not even close.
You were the one recomending he get a turbo that could make 600rwhp on pump gas right? I for one would not try making that kind of power on pump gas with piggy backs especially on 91 octane california crap gas. You dont need standalone to make 600whp but it will be alot safer if you do.
