fuel pump
pete.w
47
birmingham
just need some advice on what fuel pump im needing as me cars running major lean, im after one that fits inside the tank maybe walbro but need to know are they the same as the mk4 pumps ,would an external pump be better ? thanks pips any links
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
10secdream;1327587 said:
I would strongly suggest the Denso MK4 pump. It is more money than a Walbro but it is much more reliable. Also think about getting a fuel pressure regulator.
Ditto. The MK4 pump also flows a bit more at high pressure than the walbro.
Check out driftmotion. They have all the stuff youll need for a fuel system upgrade.
str8_6
master yuepeng
Mar 14, 2007
241
wa
agreed with everyone else. you can also use kenne bell bap when you up the boost. I know a couple mk4 guys using it on stock tt pump and doing just fine, also pushing 500+hp.
