Fuel pump?
jkbmkiii
539
Castle Rock colorado
Hey guys here is a question for you! About a week ago my fuel pump started making a pulsing sound, I had a extra fuel pump so yesterday I put the other fuel pump in the car. To my surprize when I started the car the problem still is there? Any help any body?
shaeff
Kurt is FTMFW x2!!!!
10
Around
try this:
cut the connector off the chassis side of the fuel pump, and connect a relay there. then cut off the fuel pump side, and strip the wires. run a 10 guage FUSED wire from the battery to the relay, (this will drive the pump) and ground the other Negative side of the pump to the chassis.
i did this with my walbro, and that thing is LOUD. you can hear it working both in and out of the car.
-shaeff
jkbmkiii
539
YA there is fuel in tank , and the car runs great but with that pulsing sound something has got to be wrong. Fuel press regulator? Yes the noise is from the pump!
IHI-RHC7
"The Boss"
Oregon
Unbolt the fuel pulsation damper on the back of the fuel rail, put the hardline in a hose running to a bucket, and short terminals Fp and B+ on the check connector. This should turn the pump on with no pressure, filling the bucket pretty quick. If it's quiet then, you have a return issue, if it's still loud, you probably have a pinched or clogged send line under the chassis.
-Jake
IHI-RHC7
"The Boss"
Oregon
If you pumped up some garbage through your pump, and somehow through your filter, yes.
I'd try blowing compressed air through the hard lines to try and clean them up if it's still noisy just spewing into a bucket.
-Jake
:withstupi (sorry there isn't an "I'm with Jake")
shaeff
10
Around
i'll say it again: crappy stock wiring! wire it up to a relay! it took me an hour, TOTAL, including hiding the wire 100%.
-shaeff
antman
632
TN
my 255 isn't that loud until u run it low on gas. thats when it gets loud and kinda pulses.
